SureSine
The new SureSine off-grid inverter line is comprised of six new power output classes from 150-2,500W with 120 or 230V output and 12, 24 or 48V DC input options to cover a wide range of off-grid applications requiring a high-performance, industrial-grade, pure sine wave inverter (see all versions in the SureSine Model Number Guide).
They greatly expand our inverter offering that started with the acclaimed SureSine Classic.  This new SureSine line has:
  • Wireless Android and iOS utility apps for set-up and monitoring with remote devices, plus Bluetooth communications
  • Multiple AC hardwire remote terminal options on selected models
  • Industry leading safety, low-noise and high performance NRTL certifications for reliability and system conformance
SureSine line uses industrial-grade build quality throughout, with models built around premium toroidal transformers for improved sinewave stability. Designed for the most demanding off-grid mission-critical installations
  • Superior thermal performance with fanless design means higher reliability– for example, the  300W model doesn’t derate until 45 C and delivers 200W at 60 C.  The small 150W model doesn’t derate even at 60 C!  That’s outstanding performance in their power classes.
  • Full communications capabilities include: RS485, USB, Ethernet, MS-CAN, Bluetooth while using industry-standard MODBUS protocol.
AC options include: hard-wire terminals for all markets and power levels, Type B for North America 150, 300, and 700W versions, and Universal for International 150, 300, and 700W versions.
Wireless Android and iOS mobile apps included for set-up and monitoring with remote devices.
Models: 1000W Pure Sine Wave Inverter, 150W Pure Sine Wave Inverter, 1250W Pure Sine Wave Inverter, 2500W Pure Sine Wave Inverter, 300W Pure Sine Wave Inverter, 700W Pure Sine Wave Inverter,
Specifications and Certifications by Model
Power Output Models 150W SureSine
150W
300W SureSine
300W
700W SureSine
700W
1000W SureSine
1,000W
1250W SureSine
1,250W
2500W SureSine
2,500W
*power derating at high ambient temperatures 40 C and above.
Rated Battery Voltage 12, 24 or 48V 12, 24 or 48V 12, 24 or 48V 24 or 48V 24 or 48V 48V
Min. Battery Operating Voltage 10.5/21.0/42.0V 10.5/21.0/42.0V 10.5/21.0/42.0V 21.0/42.0V 21.0/42.0V 42.0V
Max. Operating Battery Voltage 16.5/33.0/66.0V 16.5/33.0/66.0V 16.5/33.0/66.0V 33.0/66.0V 33.0/66.0V 66.0V
Continuous Power@25C 150W 300W 700W 1,000W 1,250W 2,500W
Power Surge @40C (<5 sec) 300W 600W 1,400W 2,000W 2,500W 5,000W
1 minute Surge Power 225W 450W 1,050W 1,500W 1,875W 3,750W
3 minute Surge Power 180W 360W 840W 1,200W 1,500W 3,000W
Operating Temperature Range -40 C to +60C -40 C to +60C -40 C to +60C -40 C to +60C -40 C to +60C -40 C to +60C
Peak Efficiency 89/89/90% 91/91/92% 91/90/92% 93/93% 93/94% 95%
Output Voltage Model Options 120/230V +/-5% 120/230V +/-5% 120/230V +/-5% 120/230V +/-5% 120/230V +/-5% 120/230V +/-5%
Output Frequency Options 50/60 Hz 50/60 Hz 50/60 Hz 50/60 Hz 50/60 Hz 50/60 Hz
Waveform Pure Sine Wave Pure Sine Wave Pure Sine Wave Pure Sine Wave Pure Sine Wave Pure Sine Wave
Total Harmonic Distortion (THD) <2% <2% <2% <2% <2% <2%
Self-Consumption (AC Output Off) <2.3W <2.3W <2.3W <2.3W <2.3W <2.3W
Fanless natural convection cooling Yes Yes Yes Yes Yes Yes
Operational Humidity Level 100% 100% 100% 100% 100% 100%
RS485, MS-CAN Yes Yes Yes Yes Yes Yes
USB, Ethernet No No Yes Yes Yes Yes
Bluetooth, Android & iOS Apps Yes Yes Yes Yes Yes Yes
IEC-62109-1, IEC 62109-2, IEC 62368-1 Yes Yes Yes Yes Yes Yes
IEC/EN 61000, IEC/EN 55032, IEC/EN 55011 Yes Yes Yes Yes Yes Yes
UL 1741 Yes Yes Yes Yes Yes Yes
UL 458 (pending) Yes Yes Yes Yes Yes Yes
CE/UKCA compliant Yes Yes Yes Yes Yes Yes
Data Storage (4MB/5 years internal) Yes Yes Yes Yes Yes Yes
IP Rating IP20 IP20 IP20 IP20 IP20 IP20
Manufactured in a Certified ISO 9001 Facility Yes Yes Yes Yes Yes Yes
Warranty 5 Years 5 Years 5 Years 5 Years 5 Years 5 Years
Key Features and Benefits
Videos
