Charge Controller Family Directory
Solar charge controllers use one of two technologies:
Maximum Power Point Tracking (MPPT) or Pulse Width Modulation (PWM)
MPPT technology
(Maximum Power Point Tracking)
Can convert all the solar electricity voltage possible into useable electricity. MPPT's maximum conversion efficiency is ideal for areas where seasonal, weather and shading conditions cause wide variations in solar “harvesting.” Because of additional circuitry, MPPT is more complex and expensive. Morningstar TrackStar™ MPPT technology is the industry’s reference standard
PWM technology
(Pulse-Width Modulation)
Used in places with consistent sunlight, minimal shading and no physical space limitations—such as at the top of light poles, for example. PWM controllers are simpler and more cost effective, ideal for use in systems where extracting every last watt of electricity possible from a PV array is not a concern
Integrated Series
Our flagship series of products that delivers state-of-the-art power conversion, a full complement of communications capabilities, seamless expandability, and a comprehensive platform of software functionality to cover the varied and demanding needs of industrial applications.
GenStar MPPT
Flagship in the new Integrated Series line, a fully-integrated Solar DC Systems Controller.  Unique ReadyRail architecture means that relay, shunt, and battery management, and other  functions can be added  via unique, snap-in ReadyBlocks that seamlessly expand GenStar’s capabilities.
MPPT Models
Genstar
GS-MPPT-100
100A battery current, up to 5320 Wp solar input .12, 24, 48Vdc. Meter standard.
Genstar
GS-MPPT-80
80A battery current, up to 4250 Wp solar input .12, 24, 48Vdc. Meter standard.
Genstar
GS-MPPT-60
60A battery current, up to 3200 Wp solar input .12, 24, 48Vdc. Meter standard.
Legendary reliability and performance make Morningstar Professional Series the leading charge controller brand for mission-critical off-grid solar powering applications—and the first choice of leading system designers and installers for over a quarter-century.
TriStar™
Iconic design and the first choice for larger off-grid solar electric systems up to 3kWp. Proven in mission-critical installations around the globe.
“One of the best charge controllers out there…these things are tanks.”
MPPT Models
TriStar MPPT
TS-MPPT-60M
60A battery current, up to 3200Wp solar input.12, 24, 48Vdc. Meter standard.
TriStar MPPT
TS-MPPT-60
Same as the TS-MPPT-60M but without the meter (optional).
TriStar MPPT
TS-MPPT-45
45A battery current, up to 2400Wp solar input. 12, 24, 48Vdc. Meter optional.
TriStar MPPT
TS-MPPT-30
30A battery current, up to 1600Wp solar input. 12, 24, 48Vdc. Meter optional.
TriStar MPPT 600V solar controller (standard)
TS-MPPT-60-600V -48
Standard Version of our 600V controller enabling longer "strings." Shown with optional meter.
TriStar MPPT 600V solar controller (with Disconnect Box)
TS-MPPT-60-600V -48-DB
Standard Version of our 600V controller with DC Disconnect Box enabling longer "strings."
TS-MPPT-60-600V-48-DB-TR
Standard Version of our 600V controller with Transfer Switch enabling longer "strings."
TriStar MPPT 600V
TS-MPPT-60-600V-48-DB-TR-GFPD
Standard Version of our 600V controller pre-wired with GFPD enabling longer "strings."
PWM Models
TriStar solar charge controller
TS-60M
60A solar, load or diversion current. 12, 24, 48Vdc. Meter standard.
TriStar TS-60 solar charge controller
TS-60
Same as TS-60M but without the meter (optional).
TS-45
45A solar, load or diversion current. 12, 24, 48Vdc. Meter optional.
ProStar™
Proven in over two decades of use in mid-range off-grid PV systems up to 1,100Wp. ProStar today is built on continuous improvements, with regular upgrades and enhancements-both “the legend and the latest in the same product”
“You get what you pay for, and this one is worth every penny…count on Morningstar.”
MPPT Models
ProStar MPPT
PS-MPPT-40M
40A battery current, up to 1100W. 12, 24Vdc. With meter.
ProStar MPPT solar charge controller
PS-MPPT-40
Same as the PS MPPT-40M but without the meter.
ProStar MPPT
PS-MPPT-25M
25A battery current, up to 700W. 12, 24Vdc. With meter.
PS-MPPT-25
Same as the PS MPPT-25M but without meter.
PWM Models
ProStar (Gen3) solar charge controller (metered)
PS-30M
30A solar and load current. 12, 24Vdc. With meter.
ProStar (Gen3) solar charge controller (non-metered)
PS-30
Same as PS-30M but without the meter.
PS-15M
15A solar and load current. 12, 24Vdc. With meter.
PS-15
Same as PS-15A but without the meter.
SunSaver™
Industrial-grade design that’s “the single most successful charge controller in the solar industry.” Perfect for smaller off-grid systems up to 400Wp
“…amazing product…well built and well designed…it’s the one I wish I’d bought first.”
MPPT Model
SunSaver MPPT 15L
SS-MPPT-15L
15A battery current, up to 400Wp. 12, 24Vdc with low voltage disconnect.
PWM Models
SunSaver SS 20L
SS-6-12V
6A solar and load current. 12Vdc.
SunSaver SS 20L
SS-6L-12V
6A solar and load current. 12Vdc with low voltage disconnect.
SunSaver SS 20L
SS-10-12V
10A solar and load current. 12Vdc.
SunSaver SS 20L
SS-10L-12V
10A solar and load current. 12Vdc with low voltage disconnect.
SunSaver SS 20L
SS-10L-24V
10A solar and load current. 24Vdc with low voltage disconnect.
SunSaver SS 20L
SS-20L-12V
20A solar and load current. 12Vdc with low voltage disconnect.
SunSaver SS 20L
SS-20L-24V
20A solar and load current. 24Vdc with low voltage disconnect.
SunSaver Duo™
“Love it…it was worth the extra money over other brands.”
SunSaver performance with specialized two-battery charging capability, for RV/caravan and marine use.
PWM Models
SunSaverDuo SSD/RM
SSD-25M
25A solar current. 12Vdc. Includes remote meter.
SSD-25
Same as SSD-25M but remote meter is optional.
SunKeeper™
Compact “point of use” controller mounts directly to the solar module junction box or module frame– no additional housing needed
“…great little unit…an outstanding charge controller.”
PWM Models
SunKeeper SK-6
SK-6
6A solar current. 12Vdc.
SK-12
12A solar current. 12Vdc.
SunLight™
World’s leading solar lighting controller. Used for street lighting, parking areas, facilities, signage, much more.
“Bulletproof and dependable…I will use them again and again.”
PWM Models
SunLight
SL-10L-12
SunLight
SL-10L-24
10A solar and load current. 24Vdc.
SunLight
SL-20L-12
20A solar and load current. 12Vdc.
SunLight
SL-20L-24
20A solar and load current. 24Vdc.
SunGuard™
Single-module compact controller for small systems, in professional and consumer applications.
“Rock solid…great charge controller for small systems.”
PWM Models
SunGuard SG-4
SG-4
4.5A solar current. 12Vdc.
Morningstar technology, quality and reliability that’s affordable for small residential and other applications, with more basic features. Available outside North America in selected international markets (contact an authorized distributor for information).
EcoBoost MPPT™
Affordable MPPT controllers with TrakStar solar harvesting technology for residential and other applications. Not available in US and Canada.
MPPT Models
EcoBoost MPPT with meter (straight)
EB-MPPT-40M
40A battery current. 12, 24Vdc. Two USB ports for directly charging mobile devices. With meter.
EcoBoost MPPT solar charge controller without meter
EB-MPPT-40
Same as EB-MPPT-40M but without the meter.
EB-MPPT-30M
30A battery current. 12, 24Vdc. Two USB ports for directly charging mobile devices. With meter.
EB-MPPT-30
Same as EB-MPPT-30M but without the meter.
EB-MPPT-20M
EB-MPPT-20
Same as EB-MPPT-20M but without the meter.
EcoPulse™
PWM controllers delivering essential off-grid battery regulation functions in an easy-to-use package. Not available in US and Canada.
PWM Models
EcoPulse solar charge controller with meter
EC-30M
30A battery current. 12, 24Vdc. With meter.
EcoPulse solar charge controller without meter
EC-30
Same as EC-30M but without the meter.
EC-20M
20A battery current. 12, 24Vdc. With meter.
EC-20
Same as EC-20M but without the meter.
EC-10M
10A battery current. 12, 24Vdc. With meter.
EC-10
Same as EC-10M but without the meter.
SHS™
Low cost, affordable PWM controllers for rural electrification and other projects. Includes low-voltage disconnect.
PWM Models
SHS
SHS-6
6A battery current. 12vdc. Built-in lighting control for dawn-to-dusk operation.
SHS
SHS-10
10A battery current. 12vdc.
SHS
SHS-NL-6
SHS
SHS-NL-10
