Energy Storage Partner Program
Energy Storage Partner Program Morningstar’s Energy Storage Partner™ program (ESP) is an ongoing collaboration with lithium and other advanced chemistry/technology battery brands to create Custom Settings Implementation Guides that confirm and thoroughly document optimal charge controller settings to improve battery health and performance in your systems.
[READ MORE ABOUT THE ESP PROGRAM AND CUSTOM SETTINGS (OPEN LOOP) AND BMS CLOSED LOOP SETUP]
See the chart below to access custom settings guides, configuration files, and information about supported features for your battery brand and Morningstar product. If you are using a lithium iron phosphate battery that is not included in the chart, please consult our Lithium Iron Phosphate Battery Custom Settings document.
Brand Custom Settings Guide
provides recommended absorption, float and other battery settings/info for your battery brand
MSView Custom Settings Configuration Files
MSView battery charging settings files for SunSaver, ProStar, TriStar, GenStar  product families
LiveView Custom Settings Configuration Files
LiveView battery charging settings files for GenStar product families
BMS Closed Loop Setup Guide
Use ReadyBMS Closed Loop Setup without Custom Charge Settings
Deka Duration Custom Settings Guide Deka Duration MSView Configuration Files Deka Duration LiveView Configuration Files Deka Duration Closed Loop Setup Guide
Battle Born Custom Settings Guide Battle Born MSView Configuration Files NA NA
Blue Planet Custom Settings Guide Blue Planet MSView Configuration Files NA NA
Discovery Discover Custom Settings Guide Discover MSView Configuration Files NA Discover Closed Loop Setup Guide
Dragonfly Custom Settings Guide Dragonfly MSView Configuration Files NA NA
Enerdrive Custom Settings Guide Enerdrive MSView Configuration Files NA NA
Fortress Custom Settings Guide Fortress MSView Configuration Files NA NA
genZ Custom Settings Guide genZ MSView Configuration Files NA NA
Iron Edison Custom Settings Guide Iron Edison MSView Configuration Files NA NA
Kilovault Custom Settings Guide Kilovault MSView Configuration Files NA NA
Lithionics Custom Settings Guide Lithionics MSView Configuration Files NA NA
Lithium Werks Custom Settings Guide Lithium Werks MSView Configuration Files NA NA
MK Battery MK Battery Custom Settings Guide MK Battery MSView Configuration Files NA NA
Moura Custom
Settings Guide
Moura MSView Configuration Files Moura GenStar LiveView Configuration Files NA
NEC Energy Custom Settings Guide NEC Energy MSView Configuration Files NA NA
NorthStar Custom Settings Guide NorthStar MSView Configuration Files NA NA
Polarium Polarium Custom Settings Guide Polarium MSView Configuration Files NA NA
PowerPlus Custom Settings Guide PowerPlus MSView Configuration Files PowerPlus GenStar LiveView Configuration Files NA
PylonTech Custom Settings Guide PylonTech MSView Configuration Files NA PylonTech Closed Loop Setup Guide
ReLiON Custom Settings Guide ReLion MSView Configuration Files NA NA
Sentry Custom Settings Guide Sentry MSView Configuration Files NA NA
Simpliphi Custom Settings Guide Simpliphi MSView Configuration Files NA NA
Trojan Custom Settings Guide Trojan MSView Configuration Files NA NA
UPG Custom Settings Guide MK MSView Configuration Files NA NA
WECO WECO Custom Settings Guide WECO MSView Configuration Files NA WECO Closed Loop
Setup Guide
