Contact us if you are a manufacturer / supplier or a property manager / construction company and you have questions about remote power for PoE Injectors |
Power over Ethernet (PoE) is a technology that allows you to power devices, such as network cameras and IP phones, directly through the Ethernet cable that is used to connect them to the network. This eliminates the need for separate power cables, making installation easier and more convenient. PoE Injectors are used to inject power into an Ethernet cable at the source, such as a network switch or router. They are typically used when a device requires PoE, but the network infrastructure does not natively support it.
Types of PoE
There are different standards of PoE, each with its own power output and capabilities:
- PoE (IEEE 802.3af): Provides up to 15.4 watts of power.
- PoE+ (IEEE 802.3at): Provides up to 30 watts of power.
- PoE++ (IEEE 802.3bt): Provides up to 60 or 90 watts of power.
There are Active and Passive types of PoE Injectors
- Active PoE Injectors supply power regardless of whether a PoE device is detected, potentially damaging non-PoE devices.
- Passive injectors only send power when a PoE device is connected, making them safer. Choose a passive injector for broader compatibility.
You should generally always use a passive PoE injector unless you have a very specific reason to use an active one. Here’s why:
- Safety: Passive injectors only send power when they detect a PoE-compatible device. This prevents accidental damage to non-PoE devices. Active injectors always supply power, posing a risk to your equipment.
- Compatibility: Passive injectors work with a wider range of PoE devices because they automatically adjust the voltage to the correct standard (PoE, PoE+, or PoE++). Active injectors are designed for a specific standard, so you need to make sure it matches your device.
When to consider an active PoE injector:
- Non-standard PoE devices: If you have a device that uses a non-standard PoE implementation, an active injector might be necessary. However, this is rare.
- Specific voltage requirements: You might need an active injector if your device requires a specific voltage that a passive injector cannot provide.
In most cases, a passive PoE injector is the safer and more compatible choice. If you’re unsure, check your device’s documentation or contact the manufacturer.
Benefits of Using PoE
- Simplified Installation: PoE eliminates the need for separate power cables, making installation easier and more cost-effective.
- Centralized Power Management: PoE allows you to manage the power supply for multiple devices from a central location.
- Flexibility: PoE provides flexibility in network design, as devices can be powered from any location on the network.
Solar Power for PoE Injectors and Extenders
In recent years, there has been a growing trend to use solar power to operate PoE injectors and extenders. This can be particularly useful in remote areas or situations where traditional power sources are not available.
Challenges of Using Solar Power
- Choosing the Right Equipment: Not all PoE injectors and extenders are compatible with solar power systems. It’s important to choose equipment that has a low power consumption and can be efficiently powered by solar energy.
- Installing and Maintaining Power: Installing and maintaining a solar power system can be complex, especially in remote areas. You may need to hire a professional to install the system and ensure it is working properly.
- Backup Power: In case of cloudy weather or other factors that reduce solar power generation, it’s important to have a backup power source, such as a generator or fuel cell. This can add to the cost and complexity of the system.
Conclusion
PoE injectors and extenders are essential components of modern network infrastructure, providing a convenient and efficient way to power network devices. By considering the factors involved and choosing the right equipment, you can successfully use solar power to operate your PoE injectors and extenders, even in remote or off-grid locations.
