Upcoming
Morningstar Solar Charge Controllers & Inverters
Is your system less-than-perfect? Ultimately, the health of your batteries will tell you that. But that’s a hard and expensive way to learn! Instead, learn how choosing the right solar charge controller up-front can make or break your off-grid system.
This webinar is conducted each month to introduce individuals to Morningstar and off-grid solar. It is also appropriate for experienced professionals who are looking for a refresher, or to have their pressing questions answered by one of our engineers. Attend this webinar to receive One NABCEP CE credit and learn about:
- Battery charging stages
- Differences between PWM and MPPT controllers
- Effects of oversizing PV arrays
- Efficiency variations with output power
- Electronic and environmental protections
- The latest charge controller and off-grid inverter features, capabilities and accessories
- Bluetooth mobile apps and communications
- LiveView 2.0 dashboard for remote monitoring and interactive system setup, programming, and modification
Register Now
All Times in US Eastern Time
Past Recorded Webinars
Off-Grid System Monitoring & Control
This webinar hosted by Canadian distributor, Charge Solar, features Morningstar Senior Account Executive, John White as the main presenter of off-grid system monitoring and control enabled by the GenStar MPPT solar charge controller. View this recorded webinar to learn more about Morningstar Corporation and its relationship with Charge Solar and:
- The advantages of the GenStar MPPT DC Solar Charging System
- Core GenStar MPPT features
- LiveView 2.0 system monitoring/control of loads, generator starts/stops, battery state of charge, and alerts
- ReadyBlock products that support the GenStar MPPT
- How to commission the GenStar MPPT and the compatible ReadyBlock products
- Answers to questions from webinar attendees
How to Power Telecom Sites in Challenging Locations
This special joint webinar between SFC Energy and Morningstar shares how solar hybrid fuel cell systems are used to power telecom sites in locations that are difficult to access and service because of terrain and proximity. Join this webinar to learn about:
- a green alternative to a genset (ESG Friendly Option)
- a proven extremely reliable source of off-grid power
- the components that make up a solar hybrid fuel cells system
- remote monitoring
- competitive total cost of ownership
- examples of successful deployments in telecom applications
Latest Developments Morningstar’s GenStar MPPT & ReadyBlocks as of November 2023
Special thanks to Chris Brown, AltE Store’s Chief Business Officer, for hosting and inviting Morningstar’s Brad Berwald to be the featured presenter in this webinar. Brad provided a comprehensive look at the GenStar MPPT Integrated DC system controller’s new capabilities that offer sophisticated customization and comprehensive control over your entire off-grid PV system. The GenStar MPPT is constantly evolving, and we’ve released several new software features that we want to tell you about including:
- Newest firmware updates for the GenStar and Ready Block system accessories
- New battery state of charge (SOC) feature in the Ready Shunt
- SNMP protocol support
- LiveView 2.0 integrated web app that offers a comprehensive system dashboard to monitor your entire system
- Integrated Bluetooth monitoring
- The Morningstar Android and iOS mobile apps
- Lithium and lead acid battery charging options
- Best practices to deploy your GenStar MPPT and ReadyBlocks to manage your loads, batteries, and enable complete system monitoring and communications
全新SureSine逆变器和GenStar MPPT充电控制器
请观看webinar,
(Recorded webinar about SureSines and GenStar MPPT’s delivered in Chinese)
GenStar MPPT DC Solar Charging System Overview & LiveView Demo
See a real field system specification example involving GenStar MPPT–the Industry’s first fully-integrated Solar DC System Controller in a remote industrial application that addresses:
- Configuration of external source control for equipment such as generators or fuel cells and integrating that power into your total system view
- Battery interface and charge settings including support for direct communications with lithium battery BMS systems
- Multi-tier prioritized load control with scheduling
- Aux system control functions
- Data Logging capabilities
- Remote communication and control
Upgrading your critical projects with Morningstar’s new SureSine inverters
Learn the differences in inverter design, and the key features that make an inverter “industrial grade” for higher-end remote powering applications. The new SureSines will enable solar professionals to build “all Morningstar” systems with no weak links. you’ll learn about:
- What makes an inverter industrial-grade, and the typical applications in which they’re called for
- Communications features for remote monitoring, control, and integration into industrial control systems through open standards.
- Device Configuration and real-time display of system performance with the mobile app, using the Bluetooth link
- Thermal performance and temperature ratings for use in extreme climates and industrial system enclosures
- Everything to know about application-specific product certifications and requirements
- AC Outlet choices for a variety of global markets, as well as wiring options for professional installations
- Powerful integration options with Morningstar products to offer additional control and system-level functionality
Morningstar’s Newest Innovations – SureSine & GenStar MPPT
Join Solar Builder Magazine and Morningstar to learn more about designing for success in off-grid solar installations, in this special webinar covering the new SureSine off-grid inverters and the new GenStar MPPT DC charging solution. Make sure to listen to the recording in its entirety, including the Q&A session at the end.
Get Ready for Off-Grid Success, With the Newest Innovations by the Off-Grid Experts
Join Solar Power World and Morningstar to learn more about designing for success in off-grid solar installations, in this special webinar on “Refining the Off-Grid Inverter… and reimagining the Solar Controller.” This webinar features the new SureSine off-grid inverters and the GenStar MPPT DC charging system.
How Solar Module Trends Are Disrupting Off-Grid System Design
Watch this joint webinar between SunWize and Morningstar to learn how module manufacturing trends are now impacting off-grid system design/costs more than ever. While new modules generate more power and support larger loads, they also affect decisions and choices concerning the mounting systems, charge controllers, breakers, and other balance of system components.
